I’m working on printing a new extruder head for my Ultimaker 2 that offers better head cooling. I would like to print with my Form 1 but couldn’t find the melting temp of the resin since the head heats up to 260 C when printing ABS.
The resin doesn’t really melt, it scorches. Somewhere around 350°F if I recall. But the properties go to hell before that. Your only hope is castable resin. Ask a jeweler to cast your design in silver or some metal.
To add to the above - resin also tends to crack when heated (and especially when heated and cooled repeatedly). It’s also a very poor match for mechanical parts like an extruder.
In short - i wouldn’t suggest printing an extruder from a methacrylate resin.
Thanks for the info. This is for the fan holder shroud around the extruder head to push more directional airflow towards the newly extruded material after it gets laid down.
While it won’t directly touch the extruder head it comes very close and was worried that the resin can’t handle the temps.
I’m going to put several layers of Kapton tape on it around the nozzle hole and give it a go. Will let you know how it holds up. Would be interesting to have it in bronze!
I printed a replace fan air guide for my replicator 2 on my Form printer. It serves the same function as what you are working on. Bottom line is it is holding up just fine.
