Texture Engine Failure
I am using the online texture engine. All generations seem to have a scale = 0. They look correct online, but downloaded the scale seems gone.
My vase is 170mm. I have been using it successfully, but now suddenly I get this error.
Any ideas why? Is there a limit on how often 1 can use i for free?
Thanks.
Hi, the online version has some computational limitations. We built the engine into PreForm, it should be more performant. Can you try using that?
The PreForm version can also struggles with some models, but we are working on further improvements.
Thanks. Just odd it suddenly is not working. Even using the sphere and texture from Form Lab on the page.
anyway, I’m looking to output a 3MF or STL or F3D file. I don’t see any option for that. Also apparently I need to set-up a printer, but that is confusing as well. I have a Bambu P1S printer. I don’t need to print from pre-form, but from Bambu’s printer. I just need a file type to export.
Thanks.
Ok, oddly it seems to be working, but the sharpness is now very poor, even at max sharpness. It looks good on the engine page, but now in Fusion 360. It was sharp before.
Have you been making any changes to the engine?
Thanks.
Hi, we are not making any changes to the web based texture engine anymore. Our efforts are focused on PreForm’s version.
So is this an expected result, or am I likely doing something wrong?? That higher resolution seems not possible.
Top is the output 1, second pic is as shown on online after texturing
Thanks.
