Hello,
I am trying out the Formlabs Texture Engine. When uploading a STL the preview looks great. However, when downloading the textured STL, the result is nothing like the preview and simply aweful. It looks like the exported STL has an extremely low resolution. Screenshots attached. I assume I am doing something wrong, but I don’t know what. Any ideas?
Hi Lucas - this issue is driven by the way Meshy tries to do automated meshing to define the surfaces. It splits triangles at their longest edge until either the max number of triangles is reached or all edges are under some threshold length. This doesn’t always result in a very uniform triangulation.
I got around it by repairing / building a new mesh in Fusion 360, bringing that model into Meshy, then going back to Preform.
You start w/ the CAD file you downloaded, in my case an STL file of an iPhone case. Bring the STL into Fusion 360. Go to Mesh (top menu) → Repair. Then pick Rebuild and Preserve Sharp Edges. Then OK. This should give you a decent mesh with smooth surfaces instead of those large triangles you saw. Then export it from 360. Then proceed to pull it into Meshy, apply the surface finish, then back into Preform for prep for printing.
A lot of steps, but creates an amazing effect. Hopefully, one day it will be a bit more seamless.
Hey everyone, just wanted to update this thread and let you all know that the features you’ve been asking for, like Part Hollowing, Drain Holes, Model Texturing, and more, have been added!
Some of Meshy’s limitations had to do with the web browsers and 3D file formats, but the texturing has been implemented directly into PreForm, which will solve a lot of the issues people were coming across on the web application.
Check out the full details in our latest forum post here. Thanks again for all your feedback!
