Incomplete Print
Im having in complete prints on form 4l
im guessing because of .15 touchpoint size
my question is if there is missing parts of the model,
dose that mean they are left in the resin tank somewhere?
is it mandatory to do a print sheet and waste resin, or did it just not print those parts?
Thanks,
Ryan
I would print the cleaning sheet and pour out the resin through a filter as well.
0.15mm touchpoints are likely too small
ok thanks
@eyekey, I agree with the other responses, using .15 touchpoints is too small. If you want to use very small touchpoints, you need to have larger anchor touchpoints to hold the model in place.
When you have a print failure, you can start with using a gloved hand and inspecting the resin tank for debris, but the best way to ensure that it’s clear is to use the cleaning sheet. I’m sure once you increase the touchpoint size, you’ll have fewer failures and waste less resin.
If you have any additional questions, please feel free to reach out to our support, and they’ll be happy to walk you through anything you need more information on.
