Goodmorning,
So normally I use my form2 to print in open mode with bluecast castable resin.
Works like a charm in 100, 50 or 25 micron.
But wanted to print in high temperature to create some molds. (Jewelry purpose)
Bought a new LT tank and a New batch of High Temp V2.
Currently tried 4 prints with many different settings.
Print 1:
Layer thickness 50 - mini rafts - touch point size 0.40
Z adjustment: -0.20
Result: 95% failure
Print 2:
Layer thickness 50 - normal rafts- touch point size 0.60
Z adjustment: -0.20
Added some UV Glue to the base.
Result: 95% failure
Print 3:
Z adjustment: 0
Result: 95% failure
Print4:
Layer thickness 25 - normal rafts- touch point size 0.60
Z adjustment: 0
Result: 95% failure
After every failed print I’ve filtered the resin with a paint filter so make sure to not have any issue with cloudiness.
Currently I’m quite desperate on how to solve the issue.
Hope you can help me.
