pleas help me orient this piece
https://mega.nz/#!3tkjHaTL!Q5orLqf9TJQ-_ZRfrZXVUhd6GcF7zjvt5zBe3VKAVuk
I have tried to print the piece 2 time but i always ends up in a failure. Can you please help me orient this.
kind regards,
Lakshya garg
kind regards,
Lakshya garg
If you have a problem with resolution as well, the balls are not rounded but with very small flat surfaces. You can increase the resolution of the original file. If your using SolidWorks follow this instructions:
Good luck
