hi all, having trouble locating form lab1+ software as everything is now form2, any one direct-me to where to down load 1+ software.
thanks
thanks
PreForm should be the same software they use in the F2 machines. When installed it should see your F1 when plugged in.
Hello @rocs!
Thank you so much for your question! If you already have PreForm installed you can go to the Print Settings menu(visible at the bottom of my photo below).
If your Form 1+ is connected to the computer it should appear in this list so you can select it, and then send parts to the printer.
If you get stuck please let me know and I’m happy to answer other questions!
