Same small part fails - All angles tried
Hi have one small part that I have tried several angles and it fails. Tested the STL in slicers and it checks out fine. I have never had issues with other small parts even on the same prints with this part. Not sure why this part won’t correctly print. I have tried with full raft and without, at three different rotation angles, and have prepped hundreds of successful prints over the years. Tried both auto supports and custom.
Can’t see the back of the highlighted file, have you tried , trying a flatter orientation ( it appears flat on the back, but can’t see ) if not, upside down did you try, that orientation? You said 3, but didn’t clerify, which, or where the print is failing.
Is it failing after the raft, printing some supports than failing , where in the process does it fail?
density seems thick, have you tried using Thicker supports?
What resin are you using and what is set in Preform as resin type (if in open mode)?
