i have a resin sensor level error . This stops the printer from printing and there appears no over ride anywhere. I have swopped the resin the tanks and stipp the same . There is no dirt on the inter face between the sensor on the machine and the tank.
Any one any ideas
David
Hi @horburyd,
I’m so sorry you ran into this issue! Here’s a couple of things that you can try (as per our official support article):
- Ensure that the printer is level.
Inspect the resin tank:
- Remove the resin tank.
- Check that the float can move freely.
- Reinsert and push the tank all the way back. The touchscreen displays a confirmation message when the resin tank is properly seated.
- Inspect the LevelSense board:
- Recalibrate the LevelSense board:
- Tap the wrench icon on the printer’s touchscreen. The Settings screen appears.
- Tap Maintenance. The Maintenance screen appears.
- Tap Resin Level Calibration.
- Follow the on-screen instructions:
- Tap Next to start the calibration process.
- Remove the resin tank from the printer (if one is inserted) and tap Next.
- Close the printer cover and tap Calibrate.
- Once the calibration process is complete, tap Done.
If you’re still seeing the error after trying the above, please contact our support team! They’ll be happy take to take a closer look at what might be going on and get you back to printing successfully.
i have tried all that. What is wierd is that if i remove the float mechanism in the tank the print completes
I used a Cotton Bud soaked in IPA to clean behind the Flat area of the float where it passes close to the tank wall. This helped my machine see through a very thin film of resin on the side wall of the tank. Whenever I start a new print I check the area around this flat and the side wall are very clean.
Hope this helps, All the Best Chris
