It seems the peel lines (by which i mean the random layer lines caused by the peel process shifting/deforming the last layer/layers that’s still in green state) are stronger on Form 2 than on 1+.
Any tips on reducing them (beyond the obvious post-processing suggestions)?
Obviously, there is no way to position an object optimally as there’s no hinge anymore.
Hollow objects help (reduced peel forces), but you can’t always peel everything hollow, and there’s a diminishing return there.
