A few questions for Form 1(+) owners:
- Have you noticed that your rafts are harder to remove from your build platform in version 2.9.x than in previous versions?
- Is your raft thinner than normal in version 2.9.x?
- If you contacted support with any issues related to rafts and removal or parts, what did they tell you to raise your Z height by? Did the suggestion work?
- Do your rafts shatter when you try to remove them from the build platform?
- If you had any of the above problems, were you using a version 4 vat?
- What is the condition of your build platform?
My answers:
- Yes in most cases
- Yes
- .5mm, not really
- Yes - they come off in tiny little pieces
- Yes a version 4 vat
- It seems to stick less when I used less heavily scuffed one (which certainly makes sense)
