I have been putting my build plate (FORM3) into the curing unit because it makes my small build parts pop off cleanly. But I had one of the closing plates on the build plate pop out. It looks like these two closing plates are just held onto the build plat with a rubber gasket. Should I not put the build plate into the cure unit?
It also lets me not need any gloves since all the resin is full set up.
Hi @bitsyncmaster thanks for your question.
It is possible to put a build platform in the Cure but please note two important considerations below. Because of the nature of the process, it will cure all resin on the build platform:
If there is any residual resin on the BP, it will cure and that BP is no longer usable.
Yes I have a holder so the BP sits on it’s side. So it fits no problem. This is after the wash and I wipe off any residue on the sides. The parts pop of clean because I print them on small standoffs built onto the model.
There is a cast rib inside the BP so I just drilled a 1/16" hole on the front side a little offset from the center line. I decided the front side was best because in the wash that side is very close to the edge of the wash station. Don’t over fill the wash but even if a little IPA got inside it should evaporate.
I’m pretty sure @leonhart88 meant the actual top when he said “top of all my build plates” and not the side. It shouldn’t matter, but I don’t see how that was confused.
