I have printed a few parts using the new build platform and really like the part removal benefit.
However, I noticed while cleaning the build platform 2 that there is a layer of residual resin between the spring steel and the build platform main body. Is it recommended to remove the spring steel and fully clean both parts after every print? (little bit of a hassle). Or just when switching between different resins.
I’m always concerned with potentially semi cured resin in the tank as that tends to interfere with the LPU causing failed prints. To be safe I’ve been cleaning both parts after every print but like i said its a bit of a hassle compared to the normal build platform.
