Well it used to work… when I open PreForm (version 3.37.2.361) , if I click on the top menu items, they appear way offset…
Ok so this might be a wonky Windows thing.
I’m using a laptop with an external monitor.
If I run PreForm on the laptop screen, no issue. Run it on the external HDMI monitor, that issue.
Hi LePaul, unfortunately it is a known problem with PreForm. What you can try is to change scaling of the laptop and external monitor. The setting is in Windows > Settings > Display. If the scaling of the two displays are close enough (difference is less than or equal to 25%) then menus will be in the right place. Other possible change is to set the external monitor as your main monitor.
