For those of you on Windows; if your Preform app window opens in the upper-left hand part of your screen with the title bar off-screen (so that you can’t move it by dragging on the title bar), you can get back your window by:
Click on the Preform app window
Press “ALT” + “Spacebar”
A popup context menu will show up in the upper left with options to Move, Size, Minimize, Maximize, etc. Select “Move” from this menu.
Using the arrow keys move the window back onto the screen (e.g., down arrow a few times).
Once the title bar is visible you can move it normally again.
Alternatively, you can select “Cascade windows” from the task bar context menu (right click on the Windows task bar).
