Preform App Fixed Minimum Screen Size
Can the minimum window size for PreForm be reduced as I have a great 11" MacBook Air, but I can’t see the bottom status/info bar without using an external monitor that’s bigger than my 1366x768 screen?
I can’t speak for a Macbook Air, but I had a similar issue on my windows 10 notebook (not sure of the resolution at the moment). Preform would not resize to the window properly and the status/info bar was always behind the windows taskbar. I tried many windows settings for this…the only thing I could do was set the taskbar to hide, then and only then could I see the info bar.
It seems the software has an issue with the height of it’s window, particularly on smaller screens. On my windows 10 desktop (1920x1200 on a 24in screen) I have not had an issue.
I just wish it had the courtesy to remember the position and size from the last time you opened it.
I have a 3440x1440 display and PreForm always opens to the same sized window, which is about 1/8th of my display’s size, smack in the middle of the display.
