I installed the new firmware yesterday and immediately went to print a rather basic item. Shortly after I kept getting notices of numerous resin sensor errors. The item did print out fine but it was an hour longer than it should have been. This is a brand new system with less than a dozen products built thus far. I checked the resin and the tank and saw no obvious signs of any issues… Just seems odd it worked fine till the firmware update
If you keep noticing resin sensor errors, I’d recommend opening a ticket with our support team. The newest firmware update didn’t make any modifications to resin sensing so it could be the case that there’s something else going on. In some cases, backing out the tank slightly such that it still reads but isn’t at its furthest position helps to reduce resin sensor errors.
