My print comes out badly
Hello there !
Look at my print do you have any explanation about this trouble.
Does someone already experienced this ?
Thank you.
Can you provide more details? How is it supposed to look? How was it setup in PreForm?
Hello,
Here is how it is supposed to be:
I printed in 25microns resolution.
I suggest that you try to print that part, angled at 15º, using support structures. Printing in 100µm resolution will be much faster and more then sufficient for this part.
It looks like that part is hollow, if so then it will not print that orientation since there are surfaces parallel to the build platform which will fall apart. The walls also look thin which won’t stand up to the stress
Thanks for your help guys. I no longer have any problem :slight_smile:
