Is the latest firmware version 1.2c? I ran the updater and wanted like to confirm this version number. I’m a little confused because the previous installed version was designated 1.22.
Thanks in advance for any helpful info.
G.
G.
Yep, the latest firmware is 1.2c. The firmware versioning is using a hexadecimal numbering scheme, so 1.2c is greater than 1.22. Good eyes!
Cool! Thanks for the fast reply. I figured there might be a technical reason for the numbering–just wanted to be sure for ‘peace of mind’.
G.
More to say. When you update firmware via Preform it says version 300. Which is 0x12c in hex.
I just upgraded my firmware and it came out as 1.3.
now is 1.3e
Check way… Press button 2 seconds… then… You can find your firmware version and some informations.
