I have my Form 2 in my garage where the wifi signal is weak. It recognizes the network but will not connect. So I’ve added a wifi extender halfway between my garage and my house and the Form 2 will connect to the extended network just fine. When I log into my dashboard it shows my printer as connected and idle. However in Preform it will not connect. Seems odd that it can connect in dashboard but not Pre Form. Any ideas? Thanks in advance!
OK, I figured it out. It was actually simple. I added the printer manually using it’s IP address. Works just fine on the extended network.
