Hello,
I’m having a major problem with ghost marks in my tank. I received my Form1+ about a month ago and have gone through several tanks which now all have clouding. This while i’ve only used up to 300ml’s per tank with different resins.
I opened a support ticket because my print with black resin failed completely and it turned out to be dirty mirrors. Melinda from the support team was a great help and told me exactly how to clean each mirror. Apart from that she sent me a coupon for a new tank because my black resin tank was full of very clear ghost marks as well as a dent which came into the pdms layer because of the last failed print.
This is what the tank looked liked after 300ml of black resin and the failed print: You can clearly see the ghost marks, and I’ve circled the dent as well.
Yesterday I received my new tank and I still had a project which I needed printing in black resin. So I unpacked the resin tank, inspected it to be sure it was clean. Used some novus1 and a pec-pad to wipe the tray underneath to make sure it was ultra clean.
I ran a print which was 180ml’s and this print came out perfect.
When I wanted to start a different print and I used my scraper to mix the resin in the tank, I noticed vague ghost marks again! I tried to gently scrape the scraper over the pdms layer to see if the marks could be removed as is written on the support page (http://formlabs.com/en/support/help/troubleshooting/resin-tank-damage/). This unfortunately didn’t help. I cleaned the tray with novus1 underneath again, as a last hope. but obviously that didn’t make any difference.
Anyway… to summarize: I have printed 1 single print with a brand new resin tray and used 180ml’s of resin and already the tray is full of ghost marks… Formlabs state that a tray is good for about 1L-2L’s of resin, however, these are the state of my tanks:
Black resin tank, used approx 300ml. Clouding all over the place, and there’s a black spot (3mm diameter) which has probably ruined the silicone layer completely, as it seems to be a hole/dent where the resin sticks.
NEW black resin tank. used 180ml’s. Clouding forming already, all over the PDMS layer as the print nearly covered the whole build area.
White resin tank, used approx 400ml. Clouding visible.
Clear resin tank, used approx 700ml. Clouding is visible
Grey resin tank. used approx 200ml. No clouding visible. YAY!
Here’s a photo of the brand new resin tray with clouding:
What should I do with this?
Of course there are ways to replace the PDMS layer yourself… But technically this would mean that for 1L of resin. I have to buy +/- 4 tanks… Which is €200,-…
