Galvo motor isnt working
I have formone plus.My Y axis galvomotor is dead. I realised it because i opened the machine from the back. When I powered on it one galvo which is X axis takes position by slight movement and y still dead. when i print the part in empty resin i saw the laser pointer moving only in one dirention.
plz help where can i buy that galvo motor and is there any other solution.
I would reach out to Formlabs (open a ticket). It would be fantastic if you could just buy a replacement galvo and install it.
The real problem will come after your find a replacement. You can not calibrate the machine. Formlabs must do this. So if you are able to source a replacement you will still need to send it to FL to have it calibrated.
-David
