Form 3 stuck aborting print
I noticed that noting had printed on my Form 3 when checking it after half the print time today so I tapped to abort the print. Now it’s been stuck at “Aborting print…” for an hour.
Support is offline, what can I do?
Power cycle the machine.
Thanks, that worked.
What Firmware are you using? This happened to me when I moved to 1.15. Formlabs tech support told be to revert to 1.14… Known Issue in 1.15. Re-print worked fine.
It was on 1.15.
