Running PreForm 2.9.1 and 1.44 Form 1+ for the first time, after the print was completed the bed didn’t return to top-most height.
I have not had this problem with OpenFL 2.3.3.
Did something go wrong?
The only time I had a problem with the Z not returning home is when the build platform, model, and pdms layer all stuck together. I gather this isn’t the case. Try pulling the plug and turning the printer back on. The first thing it should do is home the Z axis and perform a peel action.
Regardless if that works or not, I would open a support ticket.
The Z should always home regardless of the flavor or Preform you are using.
