I am a new user and have only used grey pro and white so far, two different tanks. All of the grey pro printed without issue. All of the white failed. It was suggested that perhaps the white tank was defective and I should try another tank. If I do change tanks and it turns out that the tank isn’t the problem how is a tank repurposed, that is, how can it be cleaned to put in a different resin.
There a post about that in the support area…
I searched the forum and can’t get a definitive answer about repurposing tanks. Can it be done? Is it advisable? In my case I’m trying to remove the tank variable as a cause of failed prints using white resin. I don’t want to “sacrifice” a new tank for a test.
That’s because you need to look in SUPPORT, not FORUM.
https://support.formlabs.com/s/article/Reprogramming-a-Form-3-Form-3B-resin-tank?language=en_US
