Daylight Saving Time problem?
I happened to be doing a print this evening, and my form2 stopped with 1h8m left on the print, saying that it’s printing but nothing’s happening. I didn’t notice exactly when this happened, but I think it was right around the switch from 2am to 1am for daylight saving time. I tried hitting pause and resume, but nothing happens. Since it’s an 8+ hour print, I’d rather not abort it or reboot the printer with this little left to print… would anything else cause it to just stop in its tracks like this?
Followup: aborting the print also failed (the display just sat there spinning), so I eventually power cycled the printer. This is the first time I’ve had a failed print due to the printer rather than curing problems :frowning:
It sounds like there might be something else going on and the timing is just a weird coincidence. If you’re still running into issues, I encourage you to get in touch with our support team so we can help to sort this out. Including Firmware and PreForm versions in your ticket helps to speed things up a bit!
