Is it possible to remove a empty cartrige of Resin on the fly and replace with New without disturbing the printing process?
Yes, you can remove the current cartridge and swap in a new one without disrupting the printing process. You can also sign up for text messages through dashboard to get a text when the current resin cartridge is low and needs to be replaced. You should however get a warning when you start a print if the printer cartridge is low and might need to get replaced.
Just the info I wanted to know…
Thank you!
