My current resin tray is at the end of its life, so I’m going to be switching to a new one. Can I pore the resin currently sitting in the old tray into my new one?
Also once my tank says it’s low I can’t start a new print because there isn’t enough resin. How can I use the rest of the resin in those tanks? Do I just have to pore it into the tray? I don’t want to do something wrong and screw up my printer…
You can pour. Though filtering is probably advisable.
You can tell the printer to ignore the low resin warning and print anyway. Worst that’ll happen is the tank will run dry before the print completes. But you should be able to use up all the resin in the tank even when the cartridge is empty.
