Thank you for the info on the plasticast Charles, I did not know about the quicker the degassing the better the casting, I do believe the harder you mix the investment the harder the investment will be , I don’t have any proof of this but I do mix as vigorously as I can. I always make sure there is no investment residue in the flasks or bases, someone told me along the way that the residue can cause the investment to set inconsistently, the people that work for me probably get tired of me reminding them.
This is one of the pieces Kat that I think you are referring to, I’ve melted about everything else, its obviously been polished tumbled and burnished, he gave it his best to make it work but it didn’t, the porosity is sharp edged and it is mainly at the top of the ring, to me it looks like contamination from a poor burnout, I am running the burnout to 1380 and holding there for 4 hours.
This is the other issue we are all having using V2 castable, I took this at 15x using my phone so its a poor photo but we all get the idea
this is the same part cast with the bluecast, very usable, FL customer support told me today ( 2-14 ) that they believe the porosity issue I’m having with the V2 is from inconsistent curing
this is a piece I cured in a curebox for more than 40 plus hours, (no typo), you can see the porosity at the top of the bezel, considering where the porosity is it feels like the ash is gathering at the very top of the casting, this model was bleached gray after 40 hours, its not a heavy ring with thick and thin spots, its like a size 4.5, so I don’t think it is a curing problem here. I used the V2 to cast this because I could not get as fine of detail using the bluecast… Ill just replace the bezel , burnish and laser and it and it will work fine , another shot of the piston ring , you can see just how rough the overall casting is, the other 2 pieces were printed using the bluecast, they are simply smoother
When I first started using the Form2, I had a platinum ring to make, I sent the print out to be cast and the caster sent it back covered in the orange peel and a lot of breakdown, he said the print was bad and sent along a 3000 dollar bill for it, it was completely unusable. I printed another one and attempted to cast it myself using a little TI casting machine, mine was better than the first one but not usable, what I’m getting at is, I used a dental investment and burned it out to 1800 degrees and had the same problems as I did burning it out at 1380 so I don’t know if its the burnout temp
we will get this Thanks you guys
