Bad Printing result
i am an intern at a research lab, i am working on 3D printing, the lab has a Form 3 printer, I tried printing my project with the rigid resin but it keeps coming out in half, i scaled my project down i still have the same problem, i would like to know if i am doing anything wrong,
Do you have pictures of the failed print and an image of what it was supposed to look like? This is often helpful in diagnosing issues.
yes i do
Hi, I have the same problems, especially with wax 40. I’m going crazy, I try and try and try, but the result still the same… If some one have a trick please help.
I have also experienced the issue of the supports breaking many times, and this has happened to me with large scale parts, which is even worse. I need a solution for this too. I couldn’t get rid of this error even when I installed a new tank, I stopped the printer, cleaned the tank and continued, but it still happens sometimes. For large-scale and thick parts, I recommend printing Full Raft. I usually do that.
Translated with DeepL.com (free version)
I evicted printing shape edges adding a large radius to avoid stresses also i changed the printing orientation several times. You can as well try this because the support might not reply
