I’ve just received a replacement printer.It doesn’t seem to be compatible with my build plate. The build plate mount arm is a different color, to be sure. What’s happening here?
@Eain_Bankins
Not sure why it is that loose but your build plate should have an adjustment screw at the pivot. Give it a few turns to tighten it up while on the arm. Then take it off the arm. Give it another turn or so. That should tighten it up.
That should get you printing until FL can explain what happened.
-David
That works, thanks!
