If there are no plans to release a linux build, does it at least work under WINE?
The win32 app does run in WINE, but naturally I couldn’t test the most important aspect-- interaction between PreForm and the printer-- without the printer. Will test that out when I receive the printer. Worst case scenario build a headless windows box to act as a print server.
Preform uses the standard libUSB 1.0 library package for the USB communication.
So if you can check that this is compatible with Wine, you might have more info.
Cheers
Feedback from lsusb -v on my FreeBSD machine. At present I have had no luck trying to get a connection to virtualbox or wine though with wine I have had black screen issues I’d be focused on before I try to worry about messing with manual usb patching.
Bus /dev/usb Device /dev/ugen4.4: ID 16d0:07eb
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 1
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x16d0
idProduct 0x07eb
bcdDevice 2.00
iManufacturer 1 Formlabs
iProduct 2 Form1
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 1
bInterfaceProtocol 1
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
can’t get device qualifier: Input/output error
can’t get debug descriptor: Input/output error
Device Status: 0x0000
(Bus Powered)
PreForm v0.8.2 seems to work fine under Ubuntu with VirtualBox. Strangely I had to install the software twice before the USB driver worked, but other than that, it seems fine. Well, at least it started a print. We’ll see in two hours if the print is successful.
Umh, correction: while the printing part works perfectly fine, there appears to be no way to select an object in the 3D-view. This means the software isn’t really usable because you can’t autoplace or scale objects. Rather disappointing. I tried with VirtualBox 4.1 and 4.2 on Windows XP (32-bit) and Windows 7 (64-bit) to no avail. The photo Jason posted looks like he was able to select the object. I guess I should try Wine instead.
Seems like a good time to make yet another plug for a native Linux version of PreForm. PLEASE! I am anxiously awaiting my form2, but less anxiously awaiting the hassle of working through a VM…
