I updated to PreForm 0.9.0 on the first day it was released. The new support system is nice and I really like the software in a Windows environment. Unfortunately it is even less compatible with VirtualBox than the 0.8.x versions were. The big problem is that the small pop-up windows for print resolution and material selection do not show up at all and I have to blindly hit enter a few times before I able to access any menus to load a file. I will try using advanced mode to save the materials to the .form files I save but the initial pop-up windows for the blank project that is created on start up will still be a problem. Maybe a preference that can be set to turn off the pop-up window would suffice. I was already used to going to the menu to set print material and thickness anyway.
Thanks,
Tom
