Hello, I have a Form 2 and used Black v3 to print a mock up circut board however on the bottom of the model there are large raised scan lines only half way down the bottom. Any ideas?
It looks like you don’t have enough supports at the bottom part of the model. As the model printed, it stabilized and stayed in place during the rest of the print.
We sometimes see this error with coplaner faces that don’t quite intersect, and it looks like the artifacts end in-line with the end of the terminal block. What software are you designing this in? You might make sure that there’s not any coplaner or intersecting geometry to see if that corrects this.
