Having a weird issue, large and small parts. It seems to either be warping or just plain printing odd where the supports meet the model. Everything past that seems to be fine, my larger print is slightly warped but I’m not really worried about that being that it seems to be a resin / curing effect that is the nature of the beast. The first one is my large print and the shield is lego sized.
Mark,
I would encourage you to write into us with your files so we can take a look. It’s possible the warping could be fixed with some support/orientation adjustments, but seeing the actual files will make suggesting a fix much easier.
Jory
The same thing often happen to me too, on different geometry/files/supports
