Using heater in printer enclosure?
I plan on using my Form 1 inside an enclosure and setting it up in my enclosed patio. Despite being insulated, the patio can get fairly cold during winter months. Should I consider using a small heater (as in grow tent or incubator) to keep resin temps warm enough?
A small thermostatically controlled heater can help, but I’d avoid anything with exposed elements or direct radiant heat aimed at the printer. Put it low and let a small fan circulate air, and control it with a separate thermostat/thermometer near the resin vat so you’re measuring the resin environment, not the heater’s own sensor. Keep within Formlabs’ recommended resin temperature range and don’t let the enclosure overheat. Since it’s a patio, also check ventilation, condensation and fire safety; an incandescent bulb or seed mat may be gentler than a grow-tent heater.
Watch my latest YouTube video, I talk about this briefly. You want self regulating heat tape.
Hi! If the patio drops below 18°C, additional heating can be a good idea. The printer heats resin to automatically, but if the room is too cold, it may take longer to reach temperature or may not maintain it, which can cause print failures. That’s why the recommended operating temperature is 18-28°C (see here). We also recommend to store resin cartridges at room temperature and keep the printer cover closed to help maintain stable conditions.
Hope this helps!
How is the video listed on YouTube? Will definitely check it out.
