Translucent Resin?
So, we have these two components, both printed together on the same printer, but as you can see, one is a lot more translucent than the other!
Does anybody know what may be causing this?
Hi @SRobson,
Thanks for reaching out! This is certainly strange, especially if both pieces were part of the same print job. I would try to isolate any differing factors in post-processing including washing, post-curing, and potentially light exposure differences. If nothing stands out, I’d recommend contacting our Support Team and sharing details about your workflow.
i’ve seen this with draft resin, after it was left inside the resin tank for too long without printing. It was like the resin got separated from the gray additive
Yeah, it looks like the pigment in the resin started to separate
