Hi Guys,
Just got back from a vacation of 4 weeks and I’m running into serious printing issues that I’ve never experienced before. The layers are really bubbly and there is a lot of partly cured resin on top. I will try to upload some photos as this will explain everything. At first it was with standard White Resin V3 that I have for while now so I thought it was the material that is expired or something. But then I exchanged to black and the same or even worse results happened. See pictures below.
When I look into the resin tank of the black material there’s a lot of small blobs of semi-cured resin or something like that. I did not see this when I opened the black or white Resin Tanks before printing. I always store my resin tanks with lid in the original cardboard box inside a steel cabinet so daylight cannot be an issue. The only thing I did for my vacation is that I placed the cleaning kit (with some IPA left in it) in the steelcabinet as wel. The lids and the tray where on the kit and there was some weight on top to keep te buckets closed. So I don’t think this can be the an issue but what do you guys think? Can it be a printer related issue?
