This picture was taken after the alchohol bath. Had to peel the thin layer off the build platform. This was printed on a form 2 with brand new resin tank and brand new grey v2 resin,
We usually see this when the laser is getting obscured one way or another. The first layer takes several passes so if something scatters the light, you get a sort of raft. It’s worth checking to make sure that there’s not any cured resin in your tank or substantial clouding. You might also check to make sure that there’s no dust or residue on the optical window. If that doesn’t seem to fix it, you should get in touch with our support team so they can continue to help troubleshoot.
