Hello.
The model has layers.
What is the cause of this?
I replaced the resin tank.
Please reply.
Hello.
Please reply.
To me, a blurry-looking print like that would indicate a problem in the optical path, and since it’s everywhere on the part instead of just one area, I would suspect that one or both of the galvanometer mirrors are not clean enough. It could also maybe be that even with a new tank, it’s resin you’ve printed with before, and that resin needs to be filtered to remove small cured particles that are floating around in it from previous prints.
Hey there! To add onto what Ike mentioned above, I would recommend getting in touch with our support team ASAP an they’d be more than happy to make sure you get all sorted out.
