Had a bit more luck with this model.
This is a stock model as well - decided to print ‘as is’ as the geometry was pretty good. Only a few open holes and Preform seemed to clean them up ok. Otherwise the skin was a continuous mesh - which was a huge win.
I was worried about thickness, so I scaled down in Preform to keep it under 8cm… so the midsection was not too thick.
My impression is that printing anything too thick causes problems, and I think this was probably right at the limit as I saw a bit of bubbling at the thickest part of the print (maybe 2cm?).
I mounted him manually, tipped back to minimize support marks on the front side. I basically jumped back and forth between support editing mode and the slicer view/main so that I could place supports exactly under any "island’ in the slice plane that was not supported. Maybe 30-45 mins of effort. (Side note - I really wish there was a way to scale a FINISHED preform model, including supports so I could test out various print sizes! Not being able to do so makes it very tempting to just model supports outside of preform, which would be a bummer - will add a wish for this).
Definitely this feels like a sweet spot for the Form1 in terms of characters… much bigger and you have to start hollowing out for sure (though I’d still like to find an efficient way to do that… I’ve not found a lot of great options in existing tools, though the z-brush tutorial referenced elsewhere on this site is a great option if that is your tool of choice.
I had no issues with platform attachment. Still seems pretty snug after 3-5 prints. I have taken to using a razor blade exclusively to get stuff off. Its a bit dicey with gloves on and resin everywhere, but it seems like the only way to get the print off without the risk of stuff breaking and flying around. I’m actually thinking of putting the platform in a vice instead of the Formlabs tray so I do not have to hold it down while trying to get the print off.
Perhaps worth noting the the smoothing of the poly goemetry (120K tris) was not great… I ran it through a smoothing filter in meshlab just to flatten stuff a bit… but it was still not great. I was surprised to see how relatively smooth things ended up. on the body. The teeth however maintained high detail and the printer delivered nicely (though I had some trouble getting a good camera shot to show that off).
BTW - he used about 50ML of grey resin. (I have black on order and will be interested to compare).
Here are some pics (again, this is not my model - just trying to see what the printer can do).
Fresh from the printer… still slimy
Probably could have used less supports, but I was playing it a bit safe. Might try again with less.
There is an interesting line at mid-shoulder all across the chest and opposite arm. As if the printer was paused, but I did not do that. It is subtle, but curious. I wonder what happened there.
Teeth came out pretty good.
Free at Last!
