Hi!
I realized my heat maps are rotated 90 degrees, was suspicious about this from the first time I saw the map but confirmed today when a part that should have appeared horizontal on the bottom left of the tank showed up on the heat map vertical and on the top left of the tank.
A simple rotation, 90 degrees counter clockwise, on the images of the dashboard should resolve this issue.
This problem is only on my dashboard or anyone noticed that?
