PreForm shows a minima, caused by an automatically set support. ![]()
It’s impossible to control the settings of the support base, so the only solution was deleting the unneeded support.
It seems to be an error in the support setting algorithm.
Rather than deleting the support altogether, try moving the support contact (on the vertical) piece), to the other edge (just slightly to the right, and regenerate supports. The algorithm should move the support base further in. See if that works
I’ve made sure to forward this to our Software Team, and we’ll work to get this corrected. From the image, it looks like that’s near enough to the boundary that it may have printed, but @Dudemeister’s suggestion of moving the contact points a bit to bring the base points in will be safer. This will also likely print fine with that support deleted
