What would cause the base on the supports to become paper-thin? Just updated the Preform software, just updated the printer software, new resin, new tank, trusty old build platform. Using Mini Rafts. I have always had a thinner base than what is in Preform, but always substantially thicker than what I have now. Thought/suggestions
The “Z” reference must have shifted. Maybe the new tank sits a little “higher” for some reason.
There’s an offset adjustment for this kind of issue, in Preform supports advanced settings. " Z-Compression Correction".
Hi @Minntronix,
Apologies for the late reply, but if you haven’t already opened a ticket with our Support Team, they should be able to help with what seems like over-compression.
