Stripes on my print
Hello
I have a problem with stripes on my print on some big parts. I have already changed the orientation and built more supports but it does not get better. The tank and Resin are new and the window is clean.
Has anyone ever had this problem and knows where the stripes come from?
It’s hard to tell what the part is like, but if you have an object that’s exactly on top of an object and they have faces that are in the exact same location then it will cause lines like that. Instead, you need to make sure that if you have a mesh on top of another it needs to extend slightly into the other mesh and it will be treated like one solid object.
