After printing directly on the build platform (but with support/mini rafts inside, the result was not very nice:
- Big gap on the side
- Although this build platform is designed for direct print, the sides have a molten look. Maybe that is normal. It probably is easy to remove with sand paper.
(The model isn’t cleaned here)
First I thought I made the venting holes for the cups too small, but because of the side openings I think this was not the issue. The problem originated next to the USB-C hole. That one was supported from the inside and one support on the outside.
What am I missing here? What can I do better?
