Ripple lines on print
My print has horizontal ripply lines across the part. Also, part of the supports did not stick to the build plate so there’s floating debris on the surface. This is the second time I have tried this print with the same result. Also after the first print I cleaned the tank strained the resin and added a new resin cartridge. I am using Flexible 80A on a Form3L
Any thoughts is appreciated.
Thanks,
Tommy
Hi @Tommy1,
Thank you for getting in touch. I’m sorry to hear about the persistent failure you’ve encountered with this print. There could be a problem with the particular tank you are using, the file setup, or the printer’s optics. I would recommend getting in touch with our Support Team for them to take a closer look.
Hi Jesse,
Thanks for getting back to me with your suggestions, and I will reach out to support to see if they can look into it further.
