Resin Sensing Error! Part 3
SO I am back with yet another printer (2nd one) and a hand full of Resin Sensor Errors!
I have cleaned, tightened, wiped, replaced as much as I can on this (New) printer and get some printing starts with all some of them going great and then for no apparent reason this error coming up over and over again…
Anyone have insight to fix it?
I have used the 1.2 mm hex I bought to adjust the screws. I have tried adjusting the tray just offset 2mm counterclockwise etc etc…
Out of ideas now…
2nd printer same problem…
If you are thinking about buying a Form 2 I would read this carefully.
Multi-part Resin Sensor series certainly aren’t what we’re going for and thanks for all of the troubleshooting you’ve done so far. Do you have a ticket open with our support team? They’ll be best suited to continue troubleshooting this with you.
