We’ve had some issues recently with all 4 of our form2’s. Essentially, the parts are all printing too “wide” . The height seems to be fine but the width is out. As this is happening on all of our printers at the same time I believe it must be a software issue. Its not great, they are around 03.mm too long but as we make dental appliances this is way to high of an error. Has anyone else noticed anything like this in the last 2 weeks or so?
Yes.it’s our problem too. we print jewelry models & our form2 doesn’t print correct size on Z-axis( height)
I think these problems is related to new firmwares or mabye new preform.
we have between 0.1 to 0.25 mm error
For most materials, we see tolerances of 100 microns across approximately 90% of the model (varies for certain features). If you’re seeing deviations much greater than this over a significant amount of the model, you should open a ticket with our support team so that we can help to troubleshoot.
