Sorry to hear about this error! This is a new one for me. As usual I would recommend getting as much info as you can to our support team so we can see what’s going on a little more closely.
I’m in contact with support now. Pretty strange though.
I manually added some resin to the tank to continue printing but now it is running dry again.
I can see a lot of debris in the tank from layers that peeled away when the tank was running dry so maybe this second time there is cured material under the float as the float seems to stay in the ‘high’ position.
I had this happen after a large print.A large slab of cured resin was wedged under the float.I only noticed it because the wiper arm kept disengaging when it hit the resin
